查看: 438|回复: 0
TMC2660电源管理评估板
发表于 2017-2-28 10:16:34 | 显示全部楼层 |阅读模式
TMC26X芯片可以算得上业界功能最强的驱动芯片,将很大提升步进电机性能。包括在最高速度,丢步检测,热量控制,微步控制等等。TMC2660集成预驱动器和功率MOSFET管,预驱动部分可以实时计算电机线圈电流,功率MOSFET将电流放大驱动电机。由于峰值输出电流达4安培,TMC2660可以驱动如NEMA23这样大尺寸的电机。TMC2660与目前热门的TMC260/261引脚软件兼容。TMC260/261一般用于支持NEMA17电机的运作。FEATURES AND BENEFITS
  • Drive Capability up to 4A motor current
  • Voltage up to 30V DC
  • Highest Resolution up to 256 microsteps per full step
  • Compact Size 10x10mm QFP-44 package
  • Low Power Dissipation, very low RDSON & synchronous rectification
  • EMI-optimized programmable slope
  • Protection & Diagnostics overcurrent, short to GND, overtemperature & undervoltage
  • stallGuard2™ high precision sensorless motor load detection coolStep™ load dependent current control for energy savings up to 75% microPlyer™
  • microstep interpolation for increased smoothness with coarse step inputs.
  • spreadCycle™ high-precision chopper for best current sine wave form and zero crossing
APPLICATIONS
  • Textile, Sewing Machines
  • Factory Automation
  • Lab Automation Liquid Handling
  • Medical
  • Office Automation
  • Printer and Scanner
  • CCTV, Security
  • ATM, Cash recycler
  • POS
  • Pumps and Valves
  • Heliostat Controller
  • CNC Machines
TMC2660_datasheet.pdf
1.36 MB, 下载次数: 1
GMT+8, 2025-1-12 18:43 , Processed in 0.114138 second(s), 17 queries , MemCache On.
