查看: 427|回复: 0
MediaTek X20开发板
发表于 2017-2-23 17:17:10 | 显示全部楼层 |阅读模式
MediaTek X20 开发板是一款诚迈科技和联发科技联合发布的符合96board规范的开源硬件,具有非常强大的运算能力和多媒体处理能力最新的曦力X20处理器,支持最新的Android系统,它就是一台mini pc,它也是您创意的引擎,曦力X20处理器——因您的创意和灵感而变得不平凡。产品参数:
项目参数
CPUMT6797 64-bit 十核2x Cortex-A72 @ 2.1GHz ~ 2.3GHz4x Cortex-A53 @ 1.85GHz4x Cortex-A53 @ 1.4GHz
多合一芯片MT6631? WLAN 802.11a/b/g/n 2.4GHz and 5GHz(On-board BT and WLAN antenna )? Bluetooth 4.1 +HS compliant? GPS (with antenna connector)
图形处理器ARM Mail-T880 MP4 700MHz
多媒体32MP @ 24fps / 25MP @ 30 fpsWQXGA 2560×1600 60fps FHD 1920×1080 120fps4Kx2K 30fps H.265 w/HDR
内存&存储 2GB LPDDR3 2CH,933MHz8GB EMMC5.1
扩展存储接口支持Micro SD card(SD3.0)
HDMI接口HDMI Full-size Type-A,支持1080P@ 30 fps
USB接口1xUSB2.0 high speed micro B(Device mode)2xUSB2.0 high speed Type A(Host mode)
IO扩展接口One 40-pin Low Speed (LS) expansion connector? UART, SPI, I2S, I2C x2, GPIO x12, DC powerOne 60-pin High Speed (HS) expansion connector? 4L-MIPI DSI, USB, I2C x2, 2L+4L-MIPI CSIone optional 16-pin analog expansion connector for stereo headset/line-out, speaker and analog line-in
用户接口4个机械按键:? Power/Reset/Volume Up/down6 LED指示灯:? 4 -user controllable? 2 -for radios (BT and WLAN activity)
供电DC JACK INPUT  +8V ~ +18V
操作系统Android Marshmallow 6.0
尺寸85mm × 54mm
MediaTek-X20-Development-Board-Hardware-User-Manual.pdf
1007.49 KB, 下载次数: 0
GMT+8, 2025-1-12 18:54 , Processed in 0.130744 second(s), 17 queries , MemCache On.
