查看: 398|回复: 0
FEZ Raptor ARM9开发板
发表于 2016-12-16 14:12:55 | 显示全部楼层 |阅读模式
FEZ Raptor基于G400-S系统模块,是一款基于强大ARM9的.NET Gadgeteering板。The FEZ Raptor ARM9 processor features 4MB Flash and 128MB DDR and runs the Microsoft .NET Micro framework (NETMF). GHI also includes a premium library to extend the NETMF core with many exclusive features. There are no additional licensing or fees, all development tools and SDKs are provided freely.Features
  • Atmel SAM9X35 400MHz 32-bit ARM 9
  • Core System Hardware: G400-S SoM
  • System Platform: .NET Micro Framework
  • Development Library: Premium
  • User available Flash: 1.4MB
  • User available RAM: 92MB
  • GPIO: 88
  • PWM: 4
  • Analog In: 12
  • UART: 6
  • SPI: 2
  • I²C: Yes
  • Networking: Ethernet TCP/IP, WiFi, SSL
  • CAN: 2
  • USB Client: Debugging, Extended
  • USB Host: Yes
  • 1-Wire: Yes
  • Real Time Clock: Yes
  • In-Field Update: Yes
  • Native LCD Controller: Yes
  • Supported Image Types: BMP, GIF, JPG
  • Memory Cards: Yes
  • File Systems: FAT16/32
  • Operating Temp: -40° to +85°C
  • Dimensions: 102x87x7.5mm
  • Weight: 28g
  • RLP: Yes
  • RLP RAM Size: 24MB
  • Gadgeteering Socket Count: 18
  • Gadgeteering Socket Type: X (x8), Y (x6), A (x4), C (x2), D, F, H (x2), I (x9), K, P, S (x3), T, U (x5), RGB (TFT LCD)
G400 SoM User Manual.pdf
1.78 MB, 下载次数: 0
GMT+8, 2025-1-12 18:10 , Processed in 0.107941 second(s), 16 queries , MemCache On.
