查看: 358|回复: 0
NUCLEO-F412ZG 开发板
发表于 2016-10-13 14:57:28 | 显示全部楼层 |阅读模式
STM32F412是ST推出的新款MCU产品,这是一款基于Cortex-M4的入门级MCU,为STM32F4 Access Line系列带来了全新的特性,除了对产品内存进行了升级,还带来了其它的新特性,例如更高的主频及可以工作在125°C的工作环境之下,MCU还提供了QSPI/FMC存储访问接口。STM32F412配备高性能存储器接口,通过双模100MHz四线SPI连接片外存储器;灵活存储控制器(FMC)支持静态存储器,对片内1MB闪存和256KB RAM进行高效扩容。新增LCD显示并口可管理16位色深的QVGA显示器或8位色深的WQVGA显示器;内部真随机数发生器(TRNG)增强了安全算法如加密算法的运算性能。此外,现有基本型产品线的USB OTG端口新增链路功率管理(LPM)和双电压轨,为设计人员省去了电平转换器,从而节省电路板空间。Features
  •  STM32 microcontroller in LQFP144 package
  •  Two types of extension resources:
    •  ST Zio connector including: support for Arduino™ Uno V3 connectivity (A0 to A5, D0 to D15) and additional signals exposing a wide range of peripherals
    •  ST morpho extension pin header footprints for full access to all STM32 I/Os
  •  ARM® mbed™ -enabled (see http://mbed.org)
  •  On-board ST-LINK/V2-1
  • debugger/programmer with SWD connector:
    •  Selection-mode switch to use the kit as a standalone ST-LINK/V2-1
    •  USB re-enumeration capability. Three different interfaces supported on USB: virtual COM port, mass storage, debug port
  •  Flexible board power supply:
    •  5 V from ST-LINK/V2-1 USB VBUS
    •  External power sources: 3.3 V and 7 - 12 V on ST Zio or ST morpho connectors, 5 V on ST morpho connector
  •  USB OTG or full-speed device with Micro-AB connector (depending on STM32 support)
  •  IEEE-802.3-2002 compliant Ethernet connector (depending on STM32 support)
  •  Three user LEDs
  •  Two push-buttons: USER and RESET
  •  LSE crystal: – 32.768 KHz crystal oscillator
  •  Comprehensive free software HAL library including a variety of software examples
  •  Support of wide choice of Integrated Development Environments (IDEs) including IAR™, Keil®, GCC-based IDEs, ARM® mbed
STM32 Nucleo Getting Started Manual.pdf
2.61 MB, 下载次数: 0
GMT+8, 2025-1-12 21:05 , Processed in 0.129870 second(s), 17 queries , MemCache On.
