查看: 759|回复: 0
DragonBoard 410c
发表于 2016-7-14 13:24:05 | 显示全部楼层 |阅读模式
DragonBoard 410c 的核心是 Qualcomm Snapdragon 处理器 — 一款 1.2GHz 四核高性能处理器,因作为 HTC 和 Motorola 的移动设备背后的大脑而闻名。DragonBoard 410c 还拥有 1GB 低功率 DDR3 Ram 和 8GB 闪存(主板上还配有额外的 microSD 扩展口)。DragonBoard 410c 真正的与众不同之处在于它的板载连通性。DragonBoard 410c 拥有内置 WiFi、蓝牙和 GPS。它还拥有 12 个 GPIO 针,以及 SPI、I2C 和 UART 连通性。DragonBoard 410c 也具有通用性。它自带预制 Android 5.1,但也可运行 Linux Ubuntu,甚至 Windows 10,并且由于该主板能够运行 32 位和 64 位,the DragonBoard 410c 还能够在许多不同应用中出色地工作。最后,DragonBoard 410c 具备良好的图像处理能力。该主板拥有 400MHz 图像处理器,能够处理 1080 HD 视频(并自带 HDMI 端口)。DragonBoard 410c 还专门配置成与 Amazon 网络服务 (AWS) 集成,令它成为 IoT、智能家居和其他连接应用的可靠之选。Features
Processor
  • Qualcomm Snapdragon 410
  • Quad-core ARM® Cortex® A53 at up to 1.2 GHz per core 64-Bit capable
  • Qualcomm Adreno 306 400MHz GPU for PC-class graphics with support for advanced APIs, including OpenGL ES 3.0, OpenCL, DirectX, and content security
Memory/Storage
  • 1GB LPDDR3 533MHz
  • 8 GB eMMC 4.51
  • SD 3.0 (UHS-I)
Video
  • 1080p@30fps HD video playback and capture with H.264 (AVC), and 720p playback with H.265 (HEVC)
Camera Support
  • Integrated ISP with support for image sensors up to 13MP
Audio
  • PCM/AAC+/MP3/WMA, ECNS, Audio+ post-processing (optional)
Connectivity
  • WLAN 802.11 b/g/n 2.4GHz
  • Bluetooth 4.1
  • GPS
  • On-board GPS antenna
  • On-board BT and WLAN antenna
I/O Interfaces
  • One USB 2.0 micro B (device mode only)
  • Two USB 2.0 (host mode only)
  • One 40-pin Low Speed (LS) expansion connector
            -UART, SPI, I2S, I2C x2, GPIO x12, DC powe
  • One 60-pin High Speed (HS) expansion connector
            -4L-MIPI DSI, USB, I2C x2, 2L+4LMIPI CSI
  • Footprint for one optional 16-pin analog expansion connector for stereo headset/ line-out, speaker and analog line-in
  • The board can be made compatible with Arduino using an add-on mezzanine board
External Storage
  • Micro SD card slot
User Interface
  • Power/Reset
  • Volume Up/down
  • 6 LED indicators
            -4 user controllable
            -2 for radios (BT and WLAN activity)
OS-support
  • Android 5.1
  • Linux based on Debian
  • Win10 IoT Core
Power, Mechanical and Environmental
  • Power: +6.5V to +18V
  • Dimensions: 54mm by 85mm meeting 96Boards™ Consumer Edition standard dimensions specifications.
  • Operating Temp: 0°C to +70°C
  • RoHS and Reach compliant
GMT+8, 2025-1-12 23:36 , Processed in 0.105194 second(s), 15 queries , MemCache On.
