查看: 262|回复: 0
AVR-CAN单片机开发板
发表于 2016-6-1 09:11:32 | 显示全部楼层 |阅读模式
AVR-CAN是学习Atmel 单片机AT90CAN128比较便宜的方式。这是非常紧凑的外形,尺寸仅有60x55mm而且CAN和RS232同时存在的同时能够让客户架起UART和CAN网络之间的桥梁。Feature
  • MCU: AT90CAN128 – 128Kb Flash, 4Kb EEPROM, 4Kb SRAM, 52 GPIO, 32working registers, a CAN controller, Real Time Clock, four Timer/Counters with PWM, 2 UARTs, Two-wire Serial Interface, an 8-channel 10-bit ADC, Watchdog Timer, SPI serial port, JTAG interface, five selectable power saving modes
  • 5x2 pin JTAG connector for programming and debugging with AVR-JTAG-L or AVR-JTAG-USB
  • RS232 DB9 female connector and driver
  • CAN controller and interface
  • User button
  • Status LED
  • 16 MHz oscillator circuit
  • 32768 Hz oscillator circuit
  • Reset button and circuit
  • On board voltage regulator (+5V)
  • Power supply LED
  • Power supply connector
  • Extension pin headers for every uC pin
  • FR-4, 1.5 mm (0.062''), soldermask, white silkscreen component print
  • Dimension 60x50 mm (2.36x1.96'')
AVR-CAN Dev Brd Manual.pdf
1.21 MB, 下载次数: 0
GMT+8, 2025-1-13 03:12 , Processed in 0.103072 second(s), 17 queries , MemCache On.
