查看: 260|回复: 0
NUCLEO-F042K6开发板
发表于 2016-5-19 10:04:10 | 显示全部楼层 |阅读模式
STM32F042x4/5233微控制器包含高性能ARMCortex®-M0的32位RISC内核,其工作频率高达48 MHz。高速嵌入式存储器(闪存高达32 KB的SRAM和6个字节),和一个大范围内的增强型外设和I / O。所有设备提供标准的通信接口(1个I2C,2个SPI/个I2S,一个HDMI CEC和两个USART),一个USB全速设备(晶体更少),一个也可以,一个12位ADC,4个16位定时器,1个32位定时器和一个先进的控制PWM定时器。Features
  •  Core: ARM® 32-bit Cortex®-M0 CPU, frequency up to 48 MHz
  •  Memories – 16 to 32 Kbytes of Flash memory
    •  6 Kbytes of SRAM with HW parity
  •   CRC calculation unit
  •  Reset and power management
    •  Digital and I/Os supply: VDD = 2 V to 3.6 V
    •  Analog supply: VDDA = from VDD to 3.6 V
    •  Selected I/Os: VDDIO2 = 1.65 V to 3.6 V
    •  Power-on/Power down reset (POR/PDR)
    • Programmable voltage detector (PVD)
    •  Low power modes: Sleep, Stop, Standby
    •  VBAT supply for RTC and backup registers
  •   Clock management
    •  4 to 32 MHz crystal oscillator
    •  32 kHz oscillator for RTC with calibration
    •  Internal 8 MHz RC with x6 PLL option
    •  Internal 40 kHz RC oscillator
    • Internal 48 MHz oscillator with automatic trimming based on ext. synchronization
  •   Up to 38 fast I/Os
    •  All mappable on external interrupt vectors
    •  Up to 24 I/Os with 5 V tolerant capability and 8 with independent supply VDDIO2
  •   5-channel DMA controller
  •   One 12-bit, 1.0 μs ADC (up to 10 channels)
    •  Conversion range: 0 to 3.6 V
    •  Separate analog supply: 2.4 V to 3.6 V
  •   Up to 14 capacitive sensing channels for touchkey, linear and rotary touch sensors
  •   Calendar RTC with alarm and periodic wakeup from Stop/Standby
STM32F042x Datasheet.pdf
1.94 MB, 下载次数: 0
GMT+8, 2025-1-13 03:19 , Processed in 0.132850 second(s), 17 queries , MemCache On.
