查看: 296|回复: 0
ATA6622 MCU评估模块
发表于 2016-5-19 09:24:02 | 显示全部楼层 |阅读模式
Atmel ATA6621, ATA6622,   ATA6624 and ATA6626是完全集成LIN收发器的系统级基础芯片(SBCS)。 窗口看门狗可调节触发时间,并提供5V /85毫安(用于Atmel ATA66223 3V /85毫安)低压降稳压器。调节器的输出电流可以通过使用外部NPN晶体管进行升压。Features:
  •  All necessary components to put the Atmel ATA6621/22/24/26 in operation are included
  •  Placeholders for some optional components for extended functions included
  •  All pins easily accessible
  •  Easily adaptable watchdog times by replacing a resistor
  •  Possibility to place an external NPN transistor for boosting up the output current of the voltage regulator (jumper J1)
  •  Possibility of selecting between master or slave operation (mounting D3 and R4)
ATA662(1,2,4,6) Application Note.pdf
1.17 MB, 下载次数: 0
GMT+8, 2025-1-13 03:06 , Processed in 0.126478 second(s), 17 queries , MemCache On.
