查看: 311|回复: 0
MN101EF63G 嵌入式单片机
发表于 2016-5-24 09:47:21 | 显示全部楼层 |阅读模式
MN101E系列8位的单片机(MN101C系列的内存扩展版)包含多种类型的外设功能。  该芯片系列非常适合应用于车身控制,车载AV,照相机,录像机,MD,TV,CD,LD,打印机,电话,家庭自动化,呼机,空调,PPC,传真机,乐器和其他应用程序。该LSI带来了嵌入式微电脑应用灵活,优化的硬件配置和简单高效的指令集。  MN101EF63系列内部有一个128 KB的ROM,RAM为10 KB。外设功能包括5个外部中断,34个内部中断包括NMI,12个定时计数器,4种类型的串行接口,可以根据CAN 2.0B,A / D转换器,LCD驱动,2种类型的看门狗定时器,以及数据的自动功能控制器。 系统配置是适合于车体控制用微控制器,如 在车身控制,加热器控制,继电器盒,或各种电机控制。Features
  •  ROM capacity: 128 KB 
  •  RAM capacity: 10 KB 
  •  Package:  TQFP064-P-1010C/TQFP064-P-1010D (10 mm × 10 mm / 0.5 mm pitch) 
  • Machine Cycle:
    •  High-speed mode
 0.05 us / 20 MHz (2.7 V to 5.5 V)
 0.125 us / 8 MHz (1.8 V to 5.5 V)
    • Low-speed mode
 62.5 ms / 32 kHz (1.8 V to 5.5 V) 
  •  Clock Gear Circuit:
 Internal system clock speed is changeable by selecting division ratio of oscillation clock. (Divided by 1, 2, 4, 16, 32, 64, 128) 
  • Oscillation Circuit: 4 types
    • High-speed (Internal oscillation: frc), High-speed (crystal/ceramic: fosc),
    •  Low-speed (Internal oscillation: frcs), Low-speed (crystal/ceramic: fx)
    •  High-speed internal oscillation 20 MHz / 16 MHz (selectable)
    • Low-speed internal oscillation 30 kHz 
  •  Clock Multiplication Circuit:
PLL circuit output clock (fpll) fosc multiplied by 2, 3, 4, 5, 6, 8, 10, 1/2 × frc multiplied by 4, 5 enabled
    •  When clock multiplication circuit is not used, fpll = fosc or fpll = frc
    •  Selectable from high-speed clock for peripheral functions (fpll-div) fpll, fpll divided by 2, 4, 8, 16 
  • Operation Mode
 NORMAL mode (high-speed mode)
 PLL mode
 SLOW mode (low-speed mode)
 HALT mode
STOP mode
 and operation clock switching 
  •  Operating Voltage:
 1.8 V to 5.5 V 
  •  Operation ambient temperature:
-40°C to +85°C (Product guaranteed 105°C is available)
MN101E63 Datasheet.pdf
369.58 KB, 下载次数: 0
GMT+8, 2025-1-13 03:11 , Processed in 0.127739 second(s), 16 queries , MemCache On.
