查看: 340|回复: 0
eZ430-Chronos 无线手表开发套件
发表于 2016-5-16 11:28:08 | 显示全部楼层 |阅读模式
eZ430-Chronos 是运动手表中基于 CC430 的高度集成的无线开发系统。它可用作手表系统的参考平台、个人局域网的个人显示器或远程数据收集的无线传感器节点。基于 CC430F6137低于 1 GHz 的射频 SoC,eZ430-Chronos 手表包含一个完整的 CC430 开发系统。它拥有一个 96 段的 LCD 显示屏,提供一个集成的压力传感器以及一个用于运动传感控制的三轴加速度计。集成的无线功能使得 Chronos 可以作为一个连接周边无线传感器(如计步器、心率显示器等)的中央集线器。eZ430-Chronos 还提供温度和电池电压测量功能,可通过基于 USB 的 CC1111 无线接口与 PC 相连。eZ430-Chronos 手表可被拆开,从而可通过定制应用对其进行重新编程,它包括一个 eZ430 USB 编程界面。TI eZ430-Chronos Features
  • Fully functional sports watch based on the CC430F6137, MSP430 with integrated <1GHz wireless transceiver.
  • Watch can be reprogrammed for custom wireless applications.
  • Highly integrated watch includes on-board three-axis accelerometer, pressure sensor, temperature sensor, battery voltage sensor.
  • 96-segment LCD display driven directly by CC430
  • Can be paired wirelessly with heart rate monitors, pedometers, or other devices based on RF transceivers such as the CC430 or CC11xx series.
  • Includes an eZ430-RF USB emulator that connects the Chronos to a PC for real-time in-system programming and debugging
eZ430-Chronos™ Development Tool User's Guide.pdf
9.14 MB, 下载次数: 0
GMT+8, 2025-1-13 03:06 , Processed in 0.116946 second(s), 16 queries , MemCache On.
