意法半导体的STM8S探索套件是促进开发,教育,推广和采样的理想工具。一旦连接到PC上,STM8S105C6T6样本通过ST-LINK使用SWIM接口,以便交换IDE或编程(STDV或STVP)和目标设备之间的数据连接。The non-intrusive debug module embedded in each STM8 device as well as the single wire debug interface will be advantageously demonstrated while building and running the demonstration software. Each example is proposed with the schematic, guidelines, the executable, and source codes ready to build with basic components commonly found in electronics labs.From the In-circuit debugger to the C compiler with various software libraries available, online support is offered through the STM8 Forum, where moderators and users will help to realize the application.The STM8S-Discovery kit is the quickest way to explore the device functionalities, create its own application, and demonstrate a function. Once programmed, the device can be separated from the debugger circuit and connected inside the designed application.Features
- STM8S105C microcontroller
- Self powered by USB cable between PC and STM8S-Discovery
- Selectable power supply voltage: 5V or 3.3V for user's application
- Embedded STLink for the STM8S
- USB interface for programming and debugging
- SWIM debug support
- Touch sensing interface
- Wrapping area for user’s own application
Benefits
- Uses the most common STM8S reference, with 32Kb of Flash, E²Data and 48 pins
- Immediate plug-and-play demonstration
- Adapts the demo to the future application environment
- Non-intrusive debug with the in-circuit debugger present on STM8S-Discovery
- Detach the debugger to run the application
- Single wire interface is always available for software upgrade
- Extend the Demo with STMicroelectronics' suggested hardware
