查看: 230|回复: 0
RAIS STM3210C入门套件
  • 签到天数: 11 天
    发表于 2015-3-2 16:57:32 | 显示全部楼层 |阅读模式
    RAIS STM3210C入门套件是一款完美的低功耗解决方案,专门应用于开发评估 ARM Cortex™-M3内核的ARM966E与ARM7TDMI。Kits come with all the hardware and software that developers need to start developing applications, including the REva evaluation board, microcontrollers, embedded RLink JTAG in-circuit debugger/programmer and Raisonance Integrated Development Environment (RIDE).The REva starter kits are available for a full range of 32-bit and 8-bit microcontrollers.Key Features
    • Raisonance software toolset with:
    • GNU C compiler
    • RIDE integrated development environment
    • High-level language debugger, editor, project manager and SIMICE simulator
    • RFlasher dedicated programming interface
    • Embedded RLink in-circuit debugger/programmer with USB interface to host PC and 20-pin JTAG application interface
    • Unlimited programming of the target device
    • Debugging of applications with debug code limitation up to 64 Kbytes
    • Interchangeable daughterboards featuring different target microcontrollers allowing development of applications for a wide range of ST microcontrollers
    • REva universal evaluation motherboard with:
    • One standard SO-DIMM connector to plug in interchangeable daughterboards.
    • Digital and analog I/O evaluation features, including on-board LEDs, buttons, switches, external analog connector, temperature sensor and potentiometer
    • I²C EEPROM and bus
    • RS-232 driver and 2 DB9 connectors
    • Prototyping area
    • VDD settings for 1.8V, 3.3V and 5V
    • USB powered, no external power required
    RAIS STM3210C入门套件数据手册.pdf
    138.36 KB, 下载次数: 0
    GMT+8, 2024-11-25 15:20 , Processed in 0.122261 second(s), 16 queries , MemCache On.
