查看: 228|回复: 0
MSP-EXP430F5529LP
  • 签到天数: 11 天
    发表于 2015-2-13 11:13:49 | 显示全部楼层 |阅读模式
    描述
    MSP430 Launchpad现在有USB!MSP-EXP430F5529LP LaunchPad是一款低价简易地的针对MSP430F5529 USBB微控制器的评估模块。此开发板是MSP430开发的简单方法,可用于编程和调试板上的仿真,以及简单的用户界面按钮和指示灯。Rapid prototyping is a snap, thanks to 40-pin BoosterPack expansion headers, as well as a wide range of available BoosterPack plug-in modules. You can quickly add features like wireless, displays, sensors, and much more. You can either design your own BoosterPack, or choose among many already available from TI and elsewhere. The 40-pin interface is compatible with any 20-pin BoosterPack that is compliant with the standard.The MSP-EXP430F5529LP LaunchPad includes the MSP430F5529 16-bit MCU with 128KB Flash, 8KB RAM, up to 25MHz CPU speed, integrated USB 2.0 PHY, 12-bit analog-to-digital converter (ADC), timers, serial communication (UART, I2C, SPI) and more! Free and Open Source USB API stacks and the MSP430 USB Descriptor Tool, available through the MSP430 USB Developers Package allowing for quick configuration of USB applications.Free software development tools are also available, such as TI’s Eclipse-based Code Composer Studio and IAR Embedded Workbench.
    特性
    • USB 2.0-enabled MSP430F5529 16-bit MCU
    • Up to 25 MHz
    • 128KB Flash and 8KB RAM
    • 12 Bit SAR ADC
    • Various USB device class examples and libraries available (CDC, HID, MSC)
    • eZ-FET lite: Open source onboard debugger with application UART
    • One USB connection for emulator and target via the use of an onboard USB hub
    • USB as power source: 5V and 3.3V through a high efficiency DC/DC converter
    • 40 pin LaunchPad standard leveraging the BoosterPack ecosystem
    包含项目
    • MSP-EXP430F5529LP LaunchPad
    • Micro USB cable
    • Quick Start Guide
    MSP-EXP430F5529LP主要文档:MSP-EXP430F5529LP LaunchPad™ Development Kit User's GuideMSP-EXP430F5529LP Hardware Design Files
    GMT+8, 2025-1-15 12:59 , Processed in 0.103974 second(s), 15 queries , MemCache On.
