TA的每日心情 | 衰 2023-3-9 16:16 |
签到天数: 15 天 连续签到: 1 天 [LV.4]偶尔看看III
该器件的设计便于把它快速容易地安装到墙上,并且也可以很容易被安装到一个外壳或面板,使得这款显示产品被广大客户使用。驱动显示器和外设的是DIABLO16处理器,一个功能非常强大的芯片,能够独立运作,采用了4D Systems Workshop的4个IDE软件编程。The Workshop IDE使图形解决方案迅速且轻松,因为它的设计是只为四维的图形处理器构建。该4Discovery拥有的功能包括,一个3.5“320x480 TFT LCD显示屏阵列,电阻式触摸,micro-SD存储存储,闪存存储,实时时钟,2线RS485接口16MB,可以作为主或从额外的转换线,可选的无线网络,可选的加密认证的安全芯片,安全传输和开关模式具有宽输入电压范围等更多功能。此4Discovery可以通过编程来存储16 MB价值图形,图像,视频,外部闪存数据,这样便不需要microSD卡。更多的图像/数据可以存储在MicroSD卡上,microSD卡可以用来升级运行的4Discovery应用程序或更新外部闪存。可选板载WiFi模块是CC3000,它可以用于连接到远程计算机或服务器和交换信息。特性:
- Powerful 3.5” Intelligent LCD-TFT display module powered by DIABLO16.
- 480x320 HVGA Resolution, RGB 65K true to life colours, TFT Screen with integrated 4-wire Resistive Touch Panel.
- Programmed over RS485 using a special programmer designed specifically for the 4Discovery.
- 6 banks of 32750 bytes of Flash memory for User Application Code and Data
- 32Kb of SRAM purely for the User.
- On-board micro-SD memory card connector for multimedia storage and data logging purposes. HC memory card support is also available for cards larger than 4GB.
- On-board external 16MB of serial Flash for multimedia storage, datalogging etc. Can be used as an alternative to microSD, or as well as.
- DOS compatible file access (FAT16 format) as well as low level access to microSD card memory.
- Display full colour images, animations, icons and video clips on chosen 4D Systems display.
- Supports all available Windows fonts.
- 5.0V or 6.3V to 36V input voltage range operation (single supply).
- Module dimensions: 74.0 x 117.0 x 21.7mm
- Weight approximately 80g.
- Display Viewing Area: 48.96 x 73.44mm
- Easily mounted to the wall using a standard light switch flush/mounting box, or can be mounted in an enclosure/panel or virtually any flat drillable surface.
- Compatible with Clipsal/HPM mounting blocks, 18mm or thicker, if the 4Discovery needs to be offset from the wall (useful for concrete block walls etc).
- RoHS and CE Compliant.
- Wireless option FCC Certified as per TI CC3000MOD specifications and carries a ‘Modular’ grant that complies with the ‘Intentional Radiator’ portion (Part 15c) for FCC Certification, Part 15.247 Transmitter Tests.
