TA的每日心情 | 衰 2023-3-9 16:16 |
签到天数: 15 天 连续签到: 1 天 [LV.4]偶尔看看III
该uLCD-35DT是3.5“480x320高分辨率智能显示模块,搭载4D Systems的DIABLO X16图形处理器,并配备了电阻式触摸显示屏,板载音频放大器和一个microSD卡插槽。驱动显示器和外设的是DIABLO16处理器,一个功能非常强大的芯片,能够独立运作,采用了4D Systems Workshop的4个IDE软件编程。The Workshop IDE使图形解决方案迅速且轻松,因为它的设计是只为四维的图形处理器构建。显示模块具有的功能,包括触摸检测,micro-SD存储存储,通用I/ O,包括模拟输入,PWM,多个TTL串口,I2C和SPI通道和多毫秒定时器,其中包括许多其他功能的阵列。凡是已被设计在过去的一个PICASO处理器理论上是可以在DIABLO16模块上运行的。如有不确定或使PICASO产品升级,请您联系4D Systems的技术支持团队。主要特性:
- Powerful 3.5” Intelligent LCD-TFT display module powered by DIABLO16
- 480x320 HVGA Resolution, RGB 65K true to life colours, TFT Screen with integrated 4-wire Resistive Touch Panel
- Easy 5 pin interface to any TTL Serial Host:
VCC, TX, RX, GND, RESET
- 6 banks of 32750 bytes of Flash memory for User Application Code and Data
- 32Kb of SRAM purely for the User
- 16 General Purpose I/O pins for user interfacing, which include 4 configurable Analog Inputs
- The GPIO is variously configurable for alternative functions such as:
3x I2C channels available 1x dedicated for SD Card and 3x configurable SPI channels available 1x dedicated and 3x configurable TTL Serial comm ports available
- Up to 6 GPIO can be used as Pin Counters
- Up to 6 GPIO for PWM (simple and Servo)
- Up to 10 GPIO for Pulse Output
- Up to 14 GPIO can be configured for Quadrature Encoder Inputs (2 channels)
- On-board micro-SD memory card connector for multimedia storage and data logging purposes. HC memory card support is also available for cards larger than 4GB. An SPI Compatible micro-SD card is required
- Alternative micro-SD memory card connector is available on special orders
- DOS compatible file access (FAT16 format) as well as low level access to card memory
- Dedicated raw PWM Audio pin driven by WAV files from micro-SD card
- Display full colour images, animations, icons and video clips on chosen 4D Systems display
- Supports all available Windows fonts
- 4.0V to 5.5V range operation (single supply)
- Module dimensions: 56.9 x 97.6 x 15.8mm (including corner plates)
- Weight ~50 g.
- Display Viewing Area: 49.7 x 77.0mm
- 4x corner plates with 2.6mm holes for mechanical mounting
- RoHS Compliant
- CE Compliant
