TA的每日心情 | 衰 2023-3-9 16:16 |
签到天数: 15 天 连续签到: 1 天 [LV.4]偶尔看看III
独家1.38“圆TFT LCD该uLCD-220RD是一种独特的1.38“圆角LCD智能显示模块,搭载了4D systems的DIABLO16图形处理器。该uLCD-220RD是专为如仪表和工具开发,还有一些特殊应用,如机器人等。驱动显示器和外设的是DIABLO16处理器,一个功能非常强大的芯片,能够独立运作,采用了4D Systems Workshop的4个IDE软件编程。The Workshop IDE使图形解决方案迅速且轻松,因为它的设计是只为四维的图形处理器构建。显示模块具有一系列的功能,包括PWM,micro-SD存储存储,通用I/ O,包括模拟输入,多重TTL串口,I2C和SPI通道正交输入,脉冲输出和多毫秒定时器等。该uLCD-220RD设有30路2.54mm节距插针头。它还具有一个10路2.54mm节距插针头,这在4D Systems的显示模块中很常见,并用于使用编程电缆和适配器与我们Workshop4 IDE模块编程。如果你正在对你的项目进行独特的研究,也许是汽车仪表仪器或拨号,甚至是机器人头部,没有比4D systems uLCD-220RD圆TFT LCD智能显示模块更合适的了。特性:
- Powerful 1.38” Intelligent LCD-TFT display module powered by DIABLO16.
- 220 x 220 Resolution (Round), RGB 65K true to life colours with LED Backlight.
- Easy 5 pin interface to any TTL Serial Host:
- 6 banks of 32750 bytes of Flash memory for User Application Code and Data
- 32Kb of SRAM purely for the User.
- 16 General Purpose I/O pins for user interfacing, which include 4 configurable Analog Inputs.
- The GPIO is variously configurable for alternative functions such as:
3x I2C channels available 1x SPI dedicated for SD Card and 3x configurable SPI channels available 1x dedicated and 3x configurable TTL Serial comm ports available
- Up to 6 GPIO can be used as Pin Counters
- Up to 6 GPIO for PWM (simple and Servo)
- Up to 10 GPIO for Pulse Output
- Up to 14 GPIO can be configured for Quadrature Encoder Inputs (2 channels)
- On-board micro-SD memory card connector for multimedia storage and data logging purposes.
- DOS compatible file access (FAT16 format) as well as low level access to card memory.
- Dedicated filtered PWM Audio pin driven by WAV files from micro-SD card, and external amplifier enable pin allows easy connection to an external amplifier for audio playback.
- Display full colour images, animations, icons and video clips on chosen 4D Systems display.
- Supports all available Windows fonts.
- 4.0V to 5.5V range operation (single supply).
- Module dimensions: 42.4 x 46.9 x 14.1mm
- Weight ~15 g.
- Display Viewing Area: Round 35.1mm Diam
- RoHS Compliant.
- CE Compliant.
