查看: 304|回复: 0
LPCXpresso™板
  • 签到天数: 15 天
    [LV.4]偶尔看看III
    发表于 2015-4-17 10:45:48 | 显示全部楼层 |阅读模式
    该LPCXpresso系列板卡为恩智浦Cortex-M微控制器提供了强大和灵活的开发系统。LPCXpresso54102板利用NXP LPC54102低功耗微控制器的设计,使您的项目尽可能的容易上手。LPCXpresso™是由NXP基于ARM的微控制器提供技术支持的低成本开发平台,该平台是由一个简单的基于Eclipse的IDE和低成本的目标板组成,其中包括一个板上调试探头。LPCXpresso是一个终端到终端的解决方案,使嵌入式工程师可以从最初开发到最终生产进行评估。特性:
    • On-board high-speed USB based debug probe with CMSIS-DAP and Redlink protocol support, can debug the on-board LPC54102 or an external target
    • External debug probe option
    • Tri-color LED, target Reset, ISP & WAKE buttons for easy testing of software functionality
    • Expansion options based on Arduino UNO and Pmod™, plus additional expansion port pins
    • On-board 1.8 V and 3.3 V regulators plus external power supply option
    • Built-in MCU power consumption and supply voltage measurement
    • UART, I²C and SPI port bridging from LPC54102 target to USB via the on-board debug probe
    • FTDI UART connector
    • Fully supported by LPCXpresso Eclipse-based IDE and GNU C/C++ toolchain, available in free and Pro versions
    LPCXpresso™板用户指南.pdf
    2.13 MB, 下载次数: 0
    GMT+8, 2024-11-25 14:46 , Processed in 0.111585 second(s), 16 queries , MemCache On.
