查看: 265|回复: 0
LPC54102传感器开发板
  • 签到天数: 15 天
    [LV.4]偶尔看看III
    发表于 2015-4-17 10:46:45 | 显示全部楼层 |阅读模式
    LPC54102传感器处理/运动控制解决方案,是由恩智浦及其合作伙伴制定的,在你开发一个永远在线的传感器处理的产品时,去提供所有你需要的。该解决方案结合LPC54102板和传感器屏蔽板(SSB),以及应用软件和Bosch Sensortec的传感器融合软件,来提供永远在线的传感器处理的一个高效的平台。特性:
    • LPC54102 MCU in an LQFP64 package
    • Built-in Link2 high-speed USB based debug probe and option for an external debug probe
    • Tri-color LED, target Reset, ISP and WAKE buttons
    • On-board regulators for 1.8 V or 3.3 V supply or external power supply options
    • Built-in MCU power consumption, sensor board and supply voltage measurement
    • UART, I²C and SPI port bridging from LPC54102 target to USB via Link2 device
    • Sensor Shield Board Bosch Sensortec sensors: BMI055 inertial measurement unit BMC150 digital compass, BMM150 magnetometer and BMP280 pressure/temperature sensor
    • Murata ZPA2326 pressure sensor
    • MAX44000 ambient light and proximity sensor
    • ACKme AMS0002 Bluetooth LE module
    • IR remote control transmitter/receiver
    • Dual Knowles digital microphones
    • Headers for easy prototyping of additional SPI and I²C sensors
    • Supported by NXP Sensor Framework and Bosch Sensortec BSX Lite sensor fusion library, available for free download at www.lpcware.com (subject to license terms and conditions)
    LPC54102传感器处理相关文件.pdf
    1.29 MB, 下载次数: 0
    GMT+8, 2024-11-25 14:29 , Processed in 0.119996 second(s), 16 queries , MemCache On.
