查看: 347|回复: 0
The TR5-Lite Stratix V FPGA 开发套件
发表于 2015-5-4 10:07:41 | 显示全部楼层 |阅读模式
The TR5-Lite Stratix V FPGA 开发套件是是一个外形超薄的PCle板,它的特点是小尺寸大功率,适用于1U系统服务器和其他严格的环境下,TR5-Lite 包括高速SFP+接口和高带宽的内存架构,高性能计算,云计算系统和超低延迟交易。Altera Stratix® V GX FPGA (5SGXEA7N2F45C2)
  • JTAG header for FPGA programming
  • Fast passive parallel (FPPx32) configuration via MAX II CPLD and flash memory
General user input / output:
  • 4 LEDs
  • 1 LED Array
  • 2 push-buttons
  • 2-position DIP switch
On-Board Clock
  • 50MHz Oscillator
  • Programmable oscillators Si570 and CDCM61004
Memory
  • 36MB 550MHZ QDRII+ SRAM
  • 2GB 933MHz DDR3 SDRAM
  • 256MB FLASH
Communication Ports
  • Two SFP+ connectors
  • One Serial ATA (SATA II) host port
  • PCI Express (PCIe) x8 edge connector
  • One RS422 transceiver with 1394 connector
TR5-Lite_User_Manual.pdf
7.8 MB, 下载次数: 0
GMT+8, 2025-1-15 06:55 , Processed in 0.130613 second(s), 16 queries , MemCache On.
