查看: 453|回复: 0
Arduino Uno 3 开发板
发表于 2015-5-12 09:55:23 | 显示全部楼层 |阅读模式
Arduino Uno Rev. 3单片机开发板是基于Atmel的 ATmega328MCU。 Arduino Uno有14个数字输入/输出引脚(其中有6个可作为PWM输出),6个模拟输入,16MHz的晶振,一个USB接口,一个电源插孔,一个ICSP头和一个复位按钮。这款Arduino的MCU板包含支持微控制器所需的一切。只需用USB电缆或电源将其与AC-DC适配器或电池连接到电脑上手。 Arduino Uno和其他开发板不同的是它不使用FTDI USB来串行驱动器芯片。相反,它具有将Atmega8U2编程为一个USB串口转换器。 The Arduino Uno MCU板可以通过USB连接外部电源供电。电源会自动选择。Power
  • Powered via USB connection or external power supply
  • - with power source selected automatically
  • External (non-USB) power from an AC-to-DC adapter
  • (wall-wart) or battery
  • Operates on external supply of 6 to 20V (7-12V recommended)
Memory
  • 32KB flash memory (with 0.5KB used for the bootloader)
  • 2KB SRAM
  • 1KB EEPROM
Input and Output
  • 14 digital pins that can be used as an input or output
  • 6 analog inputs, each of which provides 10 bits of resolution
  • (i.e. 1024 different values)
Physical Characteristics
  • Max PCB length and width of 2.7in and 2.1in
  • USB connector and power jack extend beyond PCB
  • Communication
  • Designed to communicate with a computer,
  • another Arduino, or other microcontrollers
  • ATmega328 provides UART TTL (5V)
  • serial communication
  • On-board ATmega8U2 channels serial communication over USB
  • ATmega328 supports I²C (TWI) and
  • SPI communication
Programming
  • Can be programmed with Arduino software
  • ATmega328 comes preburned with bootloader
  • for uploading new code without external
  • hardware programmer
  • MCU can be programmed through ICSP
  • (In-Circuit Serial Programming) header
Arduino UNO 数据表.pdf
76.66 KB, 下载次数: 0
GMT+8, 2025-1-15 06:25 , Processed in 0.105241 second(s), 16 queries , MemCache On.
