Embedded Artists 低功耗应用开发包(Oryx)使您能够立刻上手低功耗样板设计,它是关于 NXP LPC1100系列的低功耗设计解决方案的平台。该板设计用于评估而不是专为最后整合到消费和工业终端的产品。FEATURE:
- NXP's LPC11U37 ARM Cortex-M0 microcontroller in 48-pin LQFP package, with 10 KByte internal SRAM, 4 KByte E2PROM and 128 Kbyte internal FLASH.
- 12.0000 MHz crystal for maximum execution speed and standard serial bit rates, includingUSB requirements. The LPC11U37 runs at frequencies up to 50 MHz.
- On-board USB Device interface
- Mini-B USB connector on-board
- USB connect circuit
- Proper ESD protection
- All relevant LPC11U37 pins available on LPCXpresso compatible expansion connector (dual 27 pos, 100 mil/2.54 mm pitch rows, 900 mil apart).
- Rechargeable Lithium coin battery
- LIR2032
- Flexible charging options (via USB interfaces and external source, like solar panel)
- Other energy storage also supported (besides coin cell)
- PCF8523 low-power real time clock with I2C interface
- PCF8885 8-channel capacitive touch sensor with I2C interface
- ADXL345 3-axis accelerometer with I2C interface
- LM75B temperature sensor with I2C interface
- 96x96 pixel Memory LCD from Sharp with SPI interface
- 4 Mbit SPI FLASH for storing non-volatile parameters or other data
- Push button and LED for reset
- Push button for Wakeup functionality (on PIO0_16)
- Push button for enabling Bootloader mode of the LPC11U37
- LED on pin PIO0_7
- SWD/JTAG connector
