这款Raisonance REVA入门套件已经以低成本的解决方案完成了基于意法半导体ARM®Cortex™-M3,ARM966E™和ARM7TDMI™核心的微控制器的功能应用程序的开发和评估。开发人员需要启动开发所有的软硬件套件的应用程序。包括:REVA评估板,微控制器,嵌入式RLink JTAG调试器/编程器和Raisonance的集成开发环境(RIDE)。REva入门套件可用于全系列的32位和8位微控制器。Key Features
- Raisonance software toolset with:
- GNU C compiler
- RIDE integrated development environment
- High-level language debugger, editor, project manager and SIMICE simulator
- RFlasher dedicated programming interface
- Embedded RLink in-circuit debugger/programmer with USB interface to host PC and 20-pin JTAG application interface
- Unlimited programming of the target device
- Debugging of applications with debug code limitation up to 64 Kbytes
- Interchangeable daughterboards featuring different target microcontrollers allowing development of applications for a wide range of ST microcontrollers
- REva universal evaluation motherboard with:
- One standard SO-DIMM connector to plug in interchangeable daughterboards.
- Digital and analog I/O evaluation features, including on-board LEDs, buttons, switches, external analog connector, temperature sensor and potentiometer
- I²C EEPROM and bus
- RS-232 driver and 2 DB9 connectors
- Prototyping area
- VDD settings for 1.8V, 3.3V and 5V
- USB powered, no external power required
