查看: 2503|回复: 0
ULCD-70DT显示模块
发表于 2015-5-14 13:12:54 | 显示全部楼层 |阅读模式
ULCD-70DT显示模块是专为大型智能显示模块的需求而设计的,并且是在四维系统迄今为止最大尺寸的。驱动显示器和外设的DIABLO16处理器,一个非常有能力和强大的芯片,具有独立的功能性,采用了4D Systems Workshop 的4个IDE软件编程。由于它是专为4D的图形处理器设计的,所以 Workshop IDE轻而易举的构成了图文的解决方案。DIABLO16处理器提供了合适的FLASH和RAM升级在PICASO处理器,并且还提供了可映射的功能,如I2C,SPI,串口,PWM,脉冲输出,和正交输入,各种GPIO,同时还提供多达4个模拟输入通道。显示模块具有PWM的声音,触摸检测,micro-SD存储存储的特性,I / O的一般用途包括模拟输入,多重TTL串口,I2C和SPI通道和毫秒级的定时器,其中包括许多更多的功能。凡是过去设计的理论上可以在DIABLO16模块运行的PICASO处理器都有了细微的变化。如果您在升级 PICASO产品上有疑问或者想要设计和更换ULCD-70DT模块您可以联系4D Systems的技术支持团队。Features
  • Powerful 70" Intelligent LCD-TFT display module powered by DIABLO16
  • 800 x 480 Resolution, RGB 65K true to life colours, TFT Screen with integrated 4-wire Resistive
  • Touch Panel
  • Easy 5 pin interface to any TTL Serial Host: VCC, TX, RX, GND, RESET
  • 6 banks of 32750 bytes of Flash memory for User Application Code and Data
  • The GPIO is variously configurable for alternative functions such as:
    • 3x I²C channels available
    • 1x SPI dedicated for SD Card and 3x configurable SPI channels available
    • 1x dedicated and 3x configurable TTL Serial comm ports available
    • Up to 6 GPIO can be used as Pin Counters
    • Up to 6 GPIO for PWM (simple and Servo)
    • Up to 10 GPIO for Pulse Output
    • Up to 14 GPIO can be configured for Quadrature Encoder Inputs (2 channels)
  • 32Kb of SRAM purely for the User
  • 16 General Purpose I/O pins for user interfacing, which include 4 configurable Analog Inputs
  • On-board micro-SD memory card connector for multimedia storage and data logging purposes
  • Full sided SD memory card connector is available for volume purchases
  • DOS compatible file access (FAT16 format) as well as low level access to card memory
  • Dedicated raw PWM Audio pin driven by WAV files from micro-SD card
  • On-board audio amplifier with a tiny 8O speaker for sound generation and WAV file playback
  • Display full colour images, animations, icons and video clips on chosen 4D Systems display
  • Supports all available Windows fonts
  • 40V to 55V range operation (single supply)
  • Module dimensions: 1799 x 100 x 155mm (including tabs), Weighing ~215g
  • Display Viewing Area: 1541 x 859mm
  • 4x mounting tabs with 35mm holes for echanical mounting
ULCD-70DT-AR_datasheet.pdf
314.19 KB, 下载次数: 0
GMT+8, 2025-1-15 06:54 , Processed in 0.106381 second(s), 16 queries , MemCache On.
