查看: 292|回复: 0
LPCXpresso43S37开发板
发表于 2015-5-13 14:09:06 | 显示全部楼层 |阅读模式
LPCXpresso系列板卡为NXP's Cortex-M MCUs提供了一个强大和灵活的开发系统。NXP已经开发了LPCXpresso 43S37板的评估和原型开发LPC4300系列的MCU的功能,并设有LPC43S37在他的100引脚BGA封装选项。LPCXpresso™是一个低成本的开发平台,该平台是由一个简化的 Eclipse-based IDE和低成本的目标板,其中包括一个附加SWD调试器。 LPCXpresso是一个终端到终端的解决方案,使嵌入式工程师开发他们的应用程序从最初评估到最终生产。特性
  • LPC43S37 dual-core (M4F and M0+) MCU running at up to 208 MHz
  • On-board high-speed USB based debug probe with CMSIS-DAP and LPCXpresso IDE Redlink protocol options, can debug the on-board LPC43S37 or external target
  • Support for external debug probes
  • Tri-color LED
  • Target Reset, ISP and WAKE buttons
  • Expansion options based on Arduino UNO R3 and Pmod™, plus additional expansion port pins
  • On-board Ethernet PHY (output available at expansion connectors)
  • High speed USB A/B connector for host or slave operation
  • 8 Mb Macronix quad SPI flash
  • UART, I²C and SPI port bridging from LPC43S37 target to USB via the on-board debug probe
  • FTDI UART connector
  • A7001CM secure element
USER manual.pdf
691.64 KB, 下载次数: 0
GMT+8, 2025-1-15 06:45 , Processed in 0.111659 second(s), 16 queries , MemCache On.
