查看: 793|回复: 0
CY4501 CCG1开发板
发表于 2015-5-18 11:34:31 | 显示全部楼层 |阅读模式
CY4501 CCG1开发套件(DVK)是基于赛普拉斯USB microcontrollers的CCG1产品系列(CYPD11xx)。 DVK的主要目的是为开发一个可以容纳C型接口以及为 EMCA cables.For USB Power Delivery (PD)的USB主机和客户端系统的载体,在此套件中的主机和客户端板可配置为下行端口(DFP),一个上游端口(UFP),或双重作用端口(DRP).此套件也可作为载体评估USB C型的多种功能,采用超高速USB演示,DisplayPort的演示和电力传输演示为例。The CY4501 CCG1 DVK consists of the following contents:
  • CCG1 Client Board
  • CCG1 Host Board
  • CCG1 Electronically Marked Cable Assembly (EMCA) board
  • SuperSpeed USB -Type-A to Type-B cable
  • Two USB 2.0 Type-A to Mini-B cables
  • Quick Start Guide and associated documentation
CCG1 Host BoardThe Host Board is used to emulate a USB Type-C port that would be present on a USB host, such as a tablet or a notebook.For USB PD, the board can be configured as a DFP, UFP, or DRP.The user can connect this board to the host processor or embedded controller (EC) to develop USB PD applications.This kit contains CCG1 in a 35-ball WLCSP package (CYPD1131-35FNXI) and includes a Type-C receptacle, a SuperSpeed USB Type-B connector, and a DisplayPort connector.A USB Mini-B connector is used for HPI interface; and a SWD header for programming CCG1.CCG1 Client BoardThe Client Board is used to emulate a USB Type-C port that would be present on a USB device, such as a monitor or a docking station.It can also be used to test connectivity and communication with Type-C.Hosts (notebooks, tablets, and mobile phones).This kit contains CCG1 in a 40-pin QFN package (CYPD1134-40LQXI) and includes a Type-C receptacle, a SuperSpeed USB Type-A connector, and a DisplayPort connector.A USB Mini-B connector is used for HPI interface; and a SWD header for programming CCG1.CCG1 EMCA BoardThe EMCA Board is used to emulate a smart cable with an embedded Type-C controller at both ends.The Type-C controller on either end reports the cable characteristics (e.g., current rating) to the Type-C ports.This kit contains two CCG1 (one at either end) in 35-ball WLCSP package (CY1103-35FNXI) and includes two Type-C plugs, and SWD headers for programming each CCG1.
CY4501_CCG1_DVK_Quick_Start_Guide.pdf
6.61 MB, 下载次数: 0
CY4501_CCG1_DVK_User_Guide.pdf
2.68 MB, 下载次数: 0
GMT+8, 2024-11-25 13:00 , Processed in 0.118082 second(s), 16 queries , MemCache On.
