查看: 253|回复: 0
BCM92073X低功耗蓝牙开发套件
发表于 2015-5-20 09:56:58 | 显示全部楼层 |阅读模式
博通的BCM20732 WICED智能蓝牙低功耗(BLE)模块可以让原始设备制造商(OEM)能够实现无缝连接的外围器件,例如心脏速率监视器,计步器,门锁,灯光,接近警报和多个外围设备等。可用于简单的集成纽扣电池,在ARM®Cortex 基于M3的BCM20732将激发连接到一系列新的以前未连接的设备。与Broadcom新的SoC相比,它现在是可以运行一年以上的蓝牙智能功能的产品并且不用充电的小型电池给它们提供动力。Features
  • Bluetooth Smart compliant single mode low energy solution
  • Integrated ARM CM3 microcontroller unit (MCU), radio frequency (RF) and Embedded Bluetooth Smart Stack all on a single chip
  • Full software support, including GATT, profiles, stack, APIs and application software development kit (SDK)
  • Power optimized for single mode coin cell operation and from 1.2V supply
  • On-chip support for 2 serial peripheral interfaces (SPIs)
  • On-board 12-bit analog to digital converter (ADC)
  • On-board wakeup timer
  • Designed for fast ramp, easy manufacturing with 5x5 mm quad-flat no-leads (QFN) packaging
Applications
  • Home appliances
  • Home monitoring and control
  • Health and fitness
  • Automation and logistics
  • Digital cameras and imaging devices
  • Smart meters and energy management devices
  • Headless devices without a means of interactive configuration for connectivity
  • PAN-LAN bridge and cloud applications
  • Consumer Applications
GMT+8, 2024-11-25 12:26 , Processed in 0.107278 second(s), 15 queries , MemCache On.
