Pandaboard ES采用OMAP4460作为核心处理器。OMAP4460采用双核ARM Cortex-A9对称结构,并内置了图形加速器PowerVR SGX540,是一款功能强悍的高性能处理器,可提供对称多处理(SMP) 性能以及丰富的多媒体与3D图形支持。Pandaboard ES同时还支持WLAN与蓝牙(Bluetooth)连接技术,是一款能够在紧张的移动功率预算内确保项目充分发挥其功能的理想平台。
特性:
- Processor:OMAP4460
- POP Memory:Elpida 8Gb LPDDR2 (EDB8064B1PB-8D-F)
- PMIC:TI (TWL6030 Power Management Companion IC)
- 1Debug Support:4-pin JTAG GPIO Pins UART via DB-9 connector LEDs
- PCB: 4.5” x 4.0” (114.3 x 101.6 mm) 8 layers
- Indicators:3 LEDs (two user-controlled, one overvoltage indicator)
- HS USB 2.0 OTG Port:Mini-AB USB connector, sourced from OMAP USB Transceiver
- HS USB Host Port: Four USB HS Ports, up to 500mA current out on each, two to onboard connectors, two to expansion connectors
- Audio Connectors: 3.5mm, L+R out 3.5mm, Stereo In
- SD/MMC Connector: 6 in 1 SD/MMC/SDIO,4/8 bit support, Dual voltage
- User Interface: 1-User defined button,Reset Button,SYSBOOT3 switch
- Video: DVI-D or HDMI Optional user provided plug-in display
- Power Connector: USB Power DC Power
Camera: Not included, but supported via camera expansion connector |
