查看: 231|回复: 0
基于ZYNQ-7000 FPGA开发板
发表于 2015-6-4 16:32:22 | 显示全部楼层 |阅读模式
ZYBO(ZYNQ板)是一个功能丰富,随时可以使用的,入门级的嵌入式软件并且数字电路开发平台围绕着Xilinx Zynq-7000 系列的最小成员:Z-7010。Z-7010是基于Xilinx可编程全系统级芯片(AP SoC)架构,它紧密集成了双核ARM Cortex-A9处理器与赛灵思7系列现场可编程门阵列(FPGA)的逻辑。如果可在ZYBO再加上丰富的多媒体和连接外设,那么 Z-7010可以承载整个系统的设计。在你的设计上只需要板载存储器,视频和音频I / O,双重角色USB,以太网和SD插槽,不需要额外的硬件。Feature:
  •  650Mhz dual-core Cortex-A9 processor
  •  DDR3 memory controller with 8 DMA channels
  •  High-bandwidth peripheral controllers: 1G Ethernet, USB 2.0, SDIO
  •  Low-bandwidth peripheral controller: SPI, UART, CAN, I2C
  •  Reprogrammable logic equivalent to Artix-7 FPGA
    •  4,400 logic slices, each with four 6-input LUTs and 8 flip-flops
    •  240 KB of fast block RAM
    •  Two clock management tiles, each with a phase-locked loop (PLL) and mixed-mode clock
    • manager (MMCM)
    •  80 DSP slices
    •  Internal clock speeds exceeding 450MHz
    •  On-chip analog-to-digital converter (XADC)
ZYBO Reference Manual.pdf
1.31 MB, 下载次数: 0
GMT+8, 2024-11-25 12:39 , Processed in 0.112564 second(s), 16 queries , MemCache On.
