查看: 313|回复: 0
STM32303C评估套件
发表于 2015-6-9 15:42:55 | 显示全部楼层 |阅读模式
STM32303C-EVAL评估板设计成一个内核为ARM®Cortex®-M4的微控制器STM32F303VCT6的完整的演示和开发平台。它配备了两个串行总线,三的SPI,五个USART,一个CAN,4个12位ADC,两个12位DAC,内部40字节数据SRAM,8 KB的SRAM程序和256 KB闪存,触摸感应,USB FS,JTAG调试支持。该评价板可被用作参考设计的用户的应用程序的开发,但它不是一个最终的应用。Key Features
  • STM32F303VCT6 microcontroller
  • Four 5 V power supply options:
  • Power jack
  • ST-LINK/V2 USB connector
  • User USB connector
  • Daughterboard
  • I2S Audio DAC, stereo audio jack which supports headset with microphone
  • 2-Gbytes (or more) MicroSD card on SPI
  • I2C compatible serial interface temperature sensor, EEPROM and RF-EEPROM
  • RS-232 communication
  • IrDA transceiver
  • JTAG/SWD and ETM trace debug support, ST-LINK/V2 embedded
  • 1-Mbit SPI serial Flash memory
  • 240x320 TFT color LCD connected to the SPI interface
  • Joystick with 4-direction control and selector
  • Reset, Tamper or Key button
  • 4-color user LEDs and high brightness LED
  • Humidity sensor
  • Extension connectors for daughter board or wrapping board
  • MCU voltage: 3.3 V or adjustable 2.0 V - 3.6 V
  • USB FS connector
  • Touch-sensing buttons
  • RTC with backup battery
  • CAN 2.0A/B compliant connection
  • Light-dependent resistor (LDR)
  • IR receiver
  • Potentiometer
  • 2 motor control connectors
Evaluation board for STM32F303xx microcontrollers.pdf
482.65 KB, 下载次数: 0
GMT+8, 2024-11-25 12:24 , Processed in 0.126524 second(s), 16 queries , MemCache On.
