查看: 251|回复: 0
AD604评估板
发表于 2015-6-23 09:07:01 | 显示全部楼层 |阅读模式
AD604评估板组件具有多个输入连接、测试点、开关选择的选项和片上调整功能,为配置AD604以支持各种工作模式提供了方便。评估板只需一个能够提供200 mA或更高电流的5 V双电源,即可让两个通道同时工作。交货之前,评估板已经过全面测试。用户只需将电源和适当的测试设备连接到评估板。AD604是一款超低噪声,非常准确,双通道,线性以dB为基于时间的可变增益放大器(VGA)优化在超声波应用可变增益控制;然而,它支持任何要求低噪声,高带宽的应用,可变增益控制。在AD604的每个通道提供了300kΩ的输入电阻和为便于单极性增益控制使用。FEATURES
  • Ultralow input noise at maximum gain 0.80 nV/√Hz, 3.0 pA/√Hz
  • 2 independent linear-in-dB channels
  • Absolute gain range per channel programmable 0 dB to 48 dB (preamplifier gain = 14 dB) through 6 dB to 54 dB (preamplifier gain = 20 dB) ±1.0 dB gain accuracy
  • Bandwidth: 40 MHz (−3 dB)
  • Input resistance: 300 kΩ
  • Variable gain scaling: 20 dB/V through 40 dB/V
  • Stable gain with temperature and supply variations
  • Single-ended unipolar gain control
  • Power shutdown at lower end of gain control
  • Drive ADCs directly
AD604 User's Guide.pdf
924.65 KB, 下载次数: 0
GMT+8, 2024-11-25 13:27 , Processed in 0.118162 second(s), 16 queries , MemCache On.
