查看: 403|回复: 0
AD7689 评估板
发表于 2015-7-21 08:53:57 | 显示全部楼层 |阅读模式
AD7689是通道,16位,电荷再分配逐次逼近寄存器(SAR)模 - 数转换器(ADC),采用单电源供电,VDD工作。该AD7689包含所有组件中使用多通道,低功耗数据采集系统,包括一个真正的16位SAR ADC,无失码; 8通道(AD7689)低串扰多路复用器是有用配置输入为单端(带或不带地面),差分,或双极性一个内部低漂移基准(可选择2.5 V或4.096 V)和缓冲;一个温度传感器;一个可选极点滤波器;和一个定序器。FEATURES
  • 16-bit resolution with no missing codes
  • 4-channel (AD7682)/8-channel (AD7689) multiplexer with choice of inputs
  • Unipolar single-ended
  • Differential (GND sense)
  • Pseudobipolar
  • Throughput: 250 kSPS
  • INL: ±0.4 LSB typical, ±1.5 LSB maximum (±23 ppm or FSR)
  • Dynamic range: 93.8 dB
  • SINAD: 92.5 dB at 20 kHz
  • THD: −100 dB at 20 kHz
  • Analog input range: 0 V to VREF with VREF up to VDD
  • Multiple reference types
    • Internal selectable 2.5 V or 4.096 V
    • External buffered (up to 4.096 V)
    • External (up to VDD)
  • Internal temperature sensor (TEMP)
  • Channel sequencer, selectable 1-pole filter, busy indicator
  • No pipeline delay, SAR architecture
  • Single-supply 2.3 V to 5.5 V operation with 1.8 V to 5.5 V logic interface
  • Serial interface compatible with SPI, MICROWIRE, QSPI, and DSP
  • Power dissipation
    • 3.5 mW at 2.5 V/200 kSPS
    • 12.5 mW at 5 V/250 kSPS
  • Standby current: 50 nA
  • Low cost grade available
  • 20-lead 4 mm × 4 mm LFCSP package
  • 20-lead 2.4 mm × 2.4 mm WLCSP package
APPLICATIONS
  • Multichannel system monitoring
  • Battery-powered equipment
  • Medical instruments: ECG/EKG
  • Mobile communications: GPS
  • Power line monitoring
  • Data acquisition
  • Seismic data acquisition systems
  • Instrumentation
  • Process contro
AD7682_7689-Datasheet.pdf
760.02 KB, 下载次数: 2
GMT+8, 2025-1-14 03:49 , Processed in 0.110851 second(s), 16 queries , MemCache On.
