查看: 300|回复: 0
MLX90255 评估板
发表于 2015-7-2 08:57:02 | 显示全部楼层 |阅读模式
演示板有利于LX90255xx线性光学阵列的的评估。该板提供必要的定时和时钟信号同时支持板上成像装置或外部连接的传感器。设计者就成为空闲,而不必设计和构造的外部支持电路研究该设备的特性和性能。6到10V之间的稳压直流电源是唯一的输入信号。示波器需要观测的输出信号和分析。Feature:
  • 128 x 1 Sensor-Element Organization (1 Not Connected, 1 dummy, 128 real, 1 dummy, 1 Dark Pixel)
  • 385 DPI sensor pitch
  •  High Linearity and Uniformity for 256 Gray-Scale
  •  High Sensitivity: 1.7V @ 10μW/cm 2 @ 0.7ms integration time
  •  Special Gain Compensation for use with single LED light source
  •  Output Referenced to Ground
  •  Single 5V Supply
  •  Operation to 1MHz
128 x 1 Sensor-Element Organization (1 Not Connected, 1 dummy, 128 real, 1 dummy, 1Dark Pixel)· 385 DPI sensor pitch· High Linearity and Uniformity for 256 Gray-Scale· High Sensitivity: 1.7V @ 10μW/cm 2 @ 0.7ms integration time· Special Gain Compensation for use with single LED light source· Output Referenced to Ground· Single 5V Supply· Operation to 1MHz
evb90255 manual .pdf
119.48 KB, 下载次数: 0
GMT+8, 2025-1-14 18:05 , Processed in 0.118473 second(s), 16 queries , MemCache On.
