查看: 293|回复: 0
MMA9551L 传感器开发板
发表于 2015-7-2 09:30:39 | 显示全部楼层 |阅读模式
飞思卡尔的Xtrinsic智能动作感应平台是Xtrinsic系列的智能传感器平台中的一员。该MMA9550/1的Xtrinsic智能运动传感平台结合了专用的MEMS加速度传感器,信号调理,数据转换,和一个32位可编程微控制器。有了这个独特的混合,它把飞思卡尔的Xtrinsic智能动作感应平台变成智能,高精度,动作感应平台,能够管理多个传感器输入。这MMA9550/1的Xtrinsic智能运动传感平台可以让复杂的应用,如手势识别,计步器功能,倾斜补偿和校准,和活动监视提供所需的系统级决策。FeaturesHardware
  • Three accelerometer operating ranges:
    • ±2g suits most hand gestures (orientation detection and tit control) and freefall. For tap detection, ±4g and ±8g are supported.
    • ±4g covers most regular human dynamics (walking and jogging)
    • ±8g detects most abrupt activities (gaming)
  • Integrated temperature sensor
  • One slave SPI or I2C interface operating at up to 2 Mbps, dedicated to communication with host processor. Default value of the I2C, 7-bit address is 0x4C. (This can be customized by firmware.)
  • One master I2C interface operating at up to 400 kbps that can be used to communicate with external sensors
  • Eight selectable output data rates (ODR), from 488 Hz to 3.8 Hz
  • 10, 12, 14, and 16-bit trimmed ADC data formats available
  • 1.8V supply voltage
  • 32-bit ColdFire V1 CPU with MAC unit
  • Extensive set of power-management features and low-power modes
  • Integrated ADC can be used to convert external analog signals
  • Single-Wire, Background-Debug Mode (BDM) pin interface
  • 16-KB flash memory
  • 2-KB Random Access Memory
  • ROM-based flash controller and slave-port, command-line interpreter
  • Two-channel timer with input capture, output capture, or edge-aligned PWM
  • Programmable delay block for scheduling events relative to start of frame
  • 16-bit, modulo timer for scheduling periodic events
  • Minimal external component requirements
  • RoHS compliant (-40 to +85ºC), 16-pin, 3 x 3 x 1-mm LGA package
Software
  • This device can be programmed to provide any of the following:
    • Orientation detection (portrait/landscape)
    • High-g/Low-g threshold detection
    • Pulse detection (single, double and directional tap)
    • Tilt detection
    • Auto wake/sleep
    • Embedded, smart FIFO
    • Power management
    • Pedometer
MMA955xL manual.pdf
331.03 KB, 下载次数: 0
GMT+8, 2025-1-14 18:30 , Processed in 0.124668 second(s), 16 queries , MemCache On.
