ADIS16407/PCB是一款“分线板”产品,提供1个ADIS16407BMLZ和1个接口PCB,可简化系统设计和评估早期阶段的“原型制作”过程。ADIS16407BMLZ是完全校准的MEMS IMU,提供一个串行外设接口(SPI)用于全部数字通信 。它提供双排24引脚连接器接口,可最大限度减少电路板空间,但不支持标准扁平电缆连接。接口PCB通过双排12引脚连接器提供对ADIS16407BMLZ的访问,支持标准扁平电缆系统和手工焊接连接技术。FEATURES
- Triaxialdigital gyroscope with digital range scaling
- ±75°/sec, ±150°/sec, ±300°/sec settings
- Axis-to-axis alignment, <0.05°
- Triaxialdigital accelerometer, ±18 gminimum
- Triaxialdigital magnetometer, ±2.5 gaussminimum
- Digital barometer, 10mbarto 1200mbar
- Calibrated pressure range: 300mbar to 1100mbar
- Autonomous operation and data collection
- No external configuration commands required
- 210 ms start-up time, 4 ms sleep mode recovery time
- Factory calibrated sensitivity, bias, and axial alignment
- Calibration temperature range: −40°C to +85°C
- SPI-compatible serial interface
- Embedded temperature sensor
- Programmable operation and control
- Automatic and manual bias correction controls
- Bartlettwindow FIR length, number of taps
- Digital I/O: data ready, alarm indicator, general-purpose
- Alarms for condition monitoring
- Sleep mode for power management
- DAC output voltage
- Enable external sample clock input up to 1.1 kHz
- Single command self test
- Single-supply operation: 4.75 V to 5.25 V
- 2000 gshock survivability
- Operating temperature range:−40°C to +105°C
