查看: 292|回复: 0
MSP430 闪存仿真工具
发表于 2015-7-7 14:10:56 | 显示全部楼层 |阅读模式
MSP-FET是一个功能强大的仿真开发板迅速开始应用程序对MSP低功耗微控制器的开发。包括一个USB接口进行编程和通过JTAG接口或PIN-引脚 Spy-Bi-Wire (2线JTAG)对MSP MCU系统的调试。封闭的MSP-FET的开发工具支持开发与大多数MSP MCU和设计用于与包含MSP微控制器开发工具包一起使用;例如,在MSP MCU目标插座板。Technical Specifications
  • Software configurable supply voltage between 1.8 V and 3.6 V at 100 mA
  • Supports JTAG Security Fuse blow to protect code
  • Supports all MSP430 boards with JTAG header
  • Supports both JTAG and Spy-Bi-Wire (2-wire JTAG) debug protocols
[size=0.83em]特性:
  • USB debugging interface to connect any MSP430 MCU to a PC for real-time, in-system programming and debugging
  • Enables EnergyTrace™ technology for energy measurement and debugging on all MSP430 devices in the Code Composer Studio and IAR Embedded Workbench development environments
  • Up to 4x faster read/write speeds than the previous FET programmer version, MSP-FET430UIF
  • Includes Backchannel UART for bi-directional communication between the MSP430 and a PC - This could enable simulation of inputs from sensors as well as logging of debug data while an application is running
Getting Started With EEMBC ULPBench on MSP-EXP430FR5969.pdf
381.81 KB, 下载次数: 0
GMT+8, 2025-1-14 18:16 , Processed in 0.108967 second(s), 16 queries , MemCache On.
