ADIS16210/PCBZ是一款“分线板”产品,提供1个ADIS16210CMLZ和1个接口PCB,可简化系统设计和评估早期阶段的“原型制作”过程。ADIS16210CMLZ是完全集成/校准的数字倾斜传感器,提供一个串行外设接口(SPI)用于全部数字通信。它提供灵活的连接器接口,内置15引脚电缆边沿接口,可最大限度减少电路板空间,但不支持标准扁平电缆连接。接口PCB通过双排16引脚连接器提供针对ADIS16210CMLZ的访问,支持标准扁平电缆系统和手工焊接连接技术。接口PCB还提供了两组安装孔位:一组孔位用于将ADIS16210CMLZ与接口PCB相连,另一组用于将接口板安装在系统框架上。第一组孔位与ADIS16210CMLZ的安装孔对齐,并且已预攻螺纹以便使用M2x0.4mm机械螺丝。第二组孔位支持M2机械螺丝,并与ADISUSB评估板上的M2x0.4mm、预攻螺纹孔位对齐。FEATURES
- Triaxial, digital inclinometer system
- ±180° measurement range, roll and pitch axes
- ±90° gravity axis
- ±0.1° relative accuracy
- Triaxial, digital accelerometer, high accuracy
- ±1.7 g measurement range
- ±0.05° axis-to-axis alignment
- Digital internal temperature measurements
- Digital internal power supply measurements
- Programmable user calibration options
- Single command, frame alignment
- Manual accelerometer bias correction
- Programmable operation and control
- Sample rate/filtering
- Alarm conditions and indicator output
- Input/output: data ready, alarm, general-purpose
- Power management functions
- SPI-compatible serial interface
- Serial number and device ID
- Single-supply operation: 3.0 V to 3.6 V
- Calibrated temperature range: −40°C to +85°C
- 15 mm × 24 mm × 15 mm package with flexible connector
