查看: 333|回复: 0
CDB4353评估板
发表于 2015-7-7 13:18:55 | 显示全部楼层 |阅读模式
CDB4353评估板快速评估CS4353一个24位,高性能的立体声D / A转换器的极好方法。评估需要一个模拟信号分析仪,数字信号源,和一个+ 3.3V电源。模拟线路电平输出通过RCA音频插孔提供。CS8416数字音频接收器IC提供操作数字 - 模拟转换器所需要的系统定时和将接受的S / PDIF和EIAJ-340兼容的音频数据。评估板还可以被配置以接受在系统发育过程中的用户应用操作外部定时和数据信号。Features:
  •  Demonstrates Recommended Layout and Grounding Arrangements
  •  CS8416 Receives S/PDIF, & EIAJ-340- Compatible Digital Audio
  •  Headers for External PCM Audio
  •  Single-ended Stereo Analog Outputs
  •  Requires Only a Digital Signal Source and a +3.3 V Power Supply for a Complete Digital-toAnalog Converter System
  •  Configured by On-board Hardware Controls
  •  Power, Digital Source Select, and S/PDIF Error Indicator LEDs
  •  Current Sense Resistors for CS4353 Supplies (VA, VL, and VCP)
CDB4353_Evaluation Board.pdf
737.03 KB, 下载次数: 0
GMT+8, 2025-1-14 18:01 , Processed in 0.112601 second(s), 16 queries , MemCache On.
