查看: 257|回复: 0
Intel GALILEO 开发板
发表于 2015-7-8 09:35:35 | 显示全部楼层 |阅读模式
Intel  Galileo主板基于Intel Quark SoC X1000,一个芯片(SoC)上的32位Intel Pentium级系统。它是基于英特尔的架构硬件设计与Arduino Uno R3软件引脚兼容设计的第一基板。 在使用入门的时候Galileo板也是软件兼容Arduino的软件开发环境。Processor Features
  •  400 MHz 32-bit Intel® Pentium® instruction set architecture (ISA)-compatible processor
    •  16 KByte L1 cache
    •  512 KBytes of on-die embedded SRAM
    •  Simple to program: Single thread, single core, constant speed
    •  ACPI compatible CPU sleep states supported
    •  Integrated Real Time Clock (RTC), with optional 3V“coin cell” battery for operation between turn on cycles
Physical Characteristics
  •  10 cm long and 7 cm wide with the USB connectors, UART jack, Ethernet connector, and power jack extending beyond the former dimension.
  •  Four screw holes allow the board to be attached to a surface or case.
  •  Standard 10-pin JTAG header for debugging
  •  Reset button to reset the sketch and any attached shields
Communication
  •  10/100 Mb Ethernet RJ45 port
  •  USB 2.0 Client port
  •  USB 2.0 Host port
  •  RS-232 UART port and 3.5mm jack
  •  Mini PCI Express (mPCIe) slot with USB2.0 Host support
GalileoProdBrief.pdf
877.32 KB, 下载次数: 0
Galileo_Datasheet.pdf
634.47 KB, 下载次数: 0
GMT+8, 2025-1-14 18:29 , Processed in 0.117723 second(s), 17 queries , MemCache On.
