查看: 262|回复: 0
FNB41560 评估板
发表于 2015-7-10 09:37:43 | 显示全部楼层 |阅读模式
Fairchild的FEBSPM3SPM45_M01MTCA FEDSPM动态SPM评估板设计用于评估部分Fairchild Semiconductor的SPM3V2_V4和SPM45H SPM系列。该SPM安装为评估板上的电机功率模块驱动三相交流感应电机(ACIM),无刷直流(BLDC)电机,无刷交流(BLAC)电机,或永磁同步电机(PMSM) 。一个开关电源(SMPS)被集成到设计,以及必要的大容量电容和微控制器(MCU)接口电路。这使得Fairchild的SPM运动产品的评价与时间,费用最小的投资,及外围设备。Features
  • AC Line Input Connection
  • On-Board Bulk Capacitors
  • Bulk Capacitor Charge Indicator
  • On-Board High-Voltage SMPS
    • +15.75 VDC, +5 VDC, +3.3 VDC Outputs
  • Short-Circuit Current Protection
  • Triple Open-Emitter Connections to Negative DC Link
    • MCU Interface Connections
      • 3 High-Side, 3 Low-Side Gate Drive Inputs
      • Fault Output
      • Bus Voltage Sense Output
      • 3-Phase Current Sensing, Amplified
    • NTC Output Signal (when applicable)
    • Current Sense Resistors (when applicable)
FNB41560 datasheet.pdf
934.91 KB, 下载次数: 0
GMT+8, 2025-1-14 02:36 , Processed in 0.115267 second(s), 17 queries , MemCache On.
