查看: 215|回复: 0
FXLC95000 评估板
发表于 2015-7-9 10:46:21 | 显示全部楼层 |阅读模式
飞思卡尔的Xtrinsic FXLC95000动作感应平台集成了MEMS加速计和一个32位ColdFire MCU,同时提供自主感知与当地的计算能力来管理其他传感器,并提供最大的区别灵活性。该FXLC95000是首家向市场推出的嵌入式的可编程范围为客户特定应用和算法的检测中心。多达16个传感器的输入容易被FXLC95000传感枢纽允许校准,补偿和传感器功能可以从应用处理器卸载管理。Features
  • Hardware
    • Open MCU architecture enables differentiated creativity
    • +/-2g, 4g, 8g 3-axis digital accelerometer
    • ColdFire V1 32-bit processor with multiply accumulator block, 128KB flash and 16KB RAM
    • 4MHz SPI capability
    • 14-bit accelerometer resolution
    • Autonomous master/slave functionality
    • 1.72 to 3.6V I/O supply voltage
  • Compute and actuate locally
    • Sensor hub can manage multiple sensors with Freescale or third-party drivers
    • Pass through as needed i.e., heading
  • Software
    • Open programming model with library support
    • CodeWarrior
    • MQX™ RTOS
Applications
  • Consumer
    • Portable Navigation Devices
    • E-Readers
    • Smartphones
    • Tablets
    • Augmented Reality
  • Industrial
    • Human Machine Interface (HMI)
    • Wireless Sensor Applications
    • Remote Sensors
    • Motion Control
  • Medical/Healthcare
    • Blood Pressure Monitors
    • Telehealth System
    • Powered Patient Beds
    • Patient Monitoring Systems
    • Emotion Sensing
FXLC95000CL-Datasheet.pdf
579.01 KB, 下载次数: 0
GMT+8, 2025-1-14 18:09 , Processed in 0.119583 second(s), 16 queries , MemCache On.
