查看: 291|回复: 0
AM3517 MPU嵌入式评估套件
发表于 2015-7-10 08:47:11 | 显示全部楼层 |阅读模式
这款放大开发套件提供了一个就绪产品的硬件和软件平台,用于评估德州仪器™(TI)AM3517处理器和功能模块上的逻辑系统(SOM)。AM3517开发套件附带一个闪存的示范应用。该演示应用程序显示一个旋转的OpenGL ES的立方体在4.3“LCD。如果一个UVC兼容 USB摄像头连接到开发工具包,从摄像头中的视频可以出现在立方体的表面上。Scope of Document
  •  This User Manual is written for both the Zoom AM3517 EVM Development Kit and the Zoom AM3517 eXperimenter Kit. Where differences exist, a note within the text will explain the differences.
  •  This User Manual references specific connectors on the eXperimenter baseboard and application board. However, the discussion is limited to special use instructions; detailed information about the connectors should be referenced on the respective schematic and Bill of Material (BOM) documents. See Appendix A for links to these documents.
  •  This User Manual does not provide detailed instructions for the software included with the kits. Please refer to the specific User Guides for each respective software product for additional information. A list of additional documentation is available in Appendix A.
Requirements
  • It is assumed that the associated QuickStart Guide has been read in its entirety. See Appendix A for links to the QuickStart Guides.
  •  A development PC with CD drive, USB port, and at least 2 GB of hard drive space.
Zoom AM3517 eXperimenter Kit QSG.pdf
904.27 KB, 下载次数: 0
Zoom AM3517 Dev Kit User Manual.pdf
418.38 KB, 下载次数: 0
GMT+8, 2025-1-14 02:08 , Processed in 0.104999 second(s), 16 queries , MemCache On.
