查看: 195|回复: 0
LPC4088 MCU快速入门板
发表于 2015-7-15 10:18:07 | 显示全部楼层 |阅读模式
LPC4088快速入门板是一个易于使用的ARM Cortex-M4快速成型板在一个贯通孔DIP封装的标准(44针),定位于高性能以及低功耗的应用程序。通讯接口,大容量的内存板和LCD控制器使图形用户接口应用。Processor
  • NXP's Cortex-M4 LPC4088 microcontroller in BGA package, running at up to 120 MHz
Program Flash
  • 8 MB QSPI + 512 KB on-chip
Data Memory
  • 32 MB SDRAM (x32 bit databus for high handwidth access) + 96 KB on-chip SRAM + 4 KB on-chip E2PROM
Clock Crystals
  • 12.000 MHz main and 32.768 kHz RTC crystals
Interfaces /Connectors
  •  2x22 pin edge pins
  •  10/100Mbps Ethernet (RJ45)
  •  USB-A (USB Host interface)
  •  USB-micro B (USB Device interface)
  •  USB-micro B (mbed HDG debug interface)
  •  20 position SDW/Trace connector (ARM standard debug connector)
  •  61 pos 0.3 mm pitch FPC connector for display expansion
  •  20 pos XBee compatible connector for RF module add-on
Dimensions
  • 101 x 28 mm (104 x 28 mm with connectors)
Power
  • 4.5 - 5.5V input on pin 2, or
  •  via micro-B USB HDK connector, or
  •  via trace connector (+5V)
Other
  •  Proper ESD protection on communication interfaces
  •  CMSIS-DAP Interface On-board (debug interface functions)
  •  Supported by the mbed SDK and online tools
  •  Supported by professional tools and middleware
  •  Industrial temperature specified (-40 to +85 degrees Celsius)
  •  ISO 9001:2008 produced
  •  Production and shipping compensated for carbon dioxide emission
LPC4088 QUICKSTART BOARD.pdf
454.66 KB, 下载次数: 0
GMT+8, 2025-1-14 02:05 , Processed in 0.106167 second(s), 17 queries , MemCache On.
