查看: 438|回复: 0
ChipKIT PRO MX4开发板
发表于 2015-7-16 09:55:36 | 显示全部楼层 |阅读模式
ChipKIT Pro MX4为Cerebot MX4ck的新名称。该主板保留了该Cerebot MX4ck的所有功能。该ChipKIT Pro MX4是基于Microchip PIC32MX460F512L,32位PIC32微控制器系列的单片机开发板中一员。它与Digilent的的路线PMOD™外围模块兼容,并适合于与MicrochipMPLAB®IDE工具使用。该ChipKIT Pro MX4也是与MPIDE开发环境中使用兼容。ChipKIT结合MPIDE是一个基于PIC32系统与许多现有的Arduino™代码示例,参考资料和其他资源兼容。Features of the ChipKIT Pro MX4 Include:
  • a PIC32MX460F512L microcontroller
  •  support for programming and debugging within the Microchip MPLAB development environment
  •  support for programming within the chipKIT MPIDE development environment
  •  nine Pmod connectors for Digilent peripheral module boards
  •  eight hobby RC servo connectors
  •  USB 2.0 Device, Host, and OTG support
  •  two push buttons
  •  four LEDs
  •  multiple power supply options, including USB powered
  •  ESD protection and short circuit protection for all I/O pins.
Features of the PIC32MX460F512L Include
  •  512KB internal program flash memory
  •  32KB internal SRAM memory
  •  USB 2.0 compliant full-speed On-The-Go (OTG) controller with dedicated DMA channel
  •  two serial peripheral interfaces (SPI)
  •  two UART serial interfaces
  •  two I2C serial interfaces
  •  five 16-bit timer/counters
  •  five timer capture inputs
  •  five compare/PWM outputs
  •  sixteen 10-bit analog inputs
  •  two analog comparators
ChipKIT PRO MX4 Board Reference Manual.pdf
702.13 KB, 下载次数: 0
GMT+8, 2025-1-14 02:39 , Processed in 0.126162 second(s), 16 queries , MemCache On.
