查看: 436|回复: 0
ActivityBot机器人开发板
发表于 2015-7-16 10:17:16 | 显示全部楼层 |阅读模式
ActivityBot机器人平台教真实世界的友好,能干,强力ActivityBot的工程技术。这对首次机器人建设者一个很好的选择,以及在高中和大学的介绍到的技术和工程课程。一步一步的网页教程带你通过一个线路板设计其多核Propeller芯片,布线电路和建设传感系统让你的机器人可自行导航。继复选标记让你的乐趣快速,可选链接加入学习。该ActivityBot准备好与现成的,成品组件,附加的传感器修修补补,并升级套件。该活动板运动迷你音频插孔和插座,用于可选的XBee射频模块(不包括在内)。Features
  • Power requirements: 7.5 VDC; as five 1.5 V AA batteries (not included)
  • Communication: USB 2.0 for programming and serial port debugging
  • Dimensions: 4x4.5x5.7 inches (10x14.4x11.5 cm) assembled, without sensors
  • Operating temperature range: 32 to 113°F (0 to +45°C)
  • Easy to program in C on Windows, Mac, or Linux with the SimpleIDE software and custom Simple Libraries
  • Multicore Propeller control board makes it quick to integrate sensors, motors, and more
  • High-speed servo motors with optical encoders provide fast, consistent maneuvering
  • Breadboard and 3-pin headers let you experiment with common electronics parts, no soldering or proprietary connectors required
  • Component kit makes navigation systems that use touch, visible light, infrared light and ultrasonic sensors
  • Built-in SD card slot and microSD card are ready for data-logging and file storage
Applications
  • A great hobby kit for exploring electronics and programming
  • An affordable STEM education platform to provide a high robot/student ratio
Kit Contents
  • Propeller Activity Board
  • Two High Speed Continuous Rotation Servos
  • PING))) Ultrasonic Distance Sensor
  • Small Robot Chassis
  • ActivityBot Encoder Kit
  • Two ActivityBot Encoder wheels with O-ring tires
  • 1" Tail Wheel Ball
  • 5 AA Battery Holder
  • Parallax Screwdriver
  • Parallax Combination Wrench
  • USB A to Mini-B Cable
  • 2 GB microSD card
  • Electronics pack with passive components plus light, touch, and infrared sensors
  • Hardware pack with all the screws, nuts, and standoffs needed
Parallax-Small-Robot-Comparison-Chart-v1.0..pdf
793.45 KB, 下载次数: 0
Parallax-Small-Robot-Comparison-Chart-v1.1.pdf
256.58 KB, 下载次数: 0
GMT+8, 2025-1-14 02:18 , Processed in 0.114063 second(s), 16 queries , MemCache On.
