EDM1 SOM 入门开发套件是紧凑型模块,具有各种传感器和互联的移动嵌入式设备的快速发展。载板提供了HDMI,TTL,LVDS和显示接口,并通过沟通双重的PCI Express(带SIM cardslots)。它还提供了双CAN总线,双UART,USB,以及8个GPIO用于工业控制。Features
- System on Module: EDM Type 1 compliant
- Video: 1x HDMI, 1 channel LVDS 18/24 bit
- Touch panel: TSC2046 (4 wire by SPI)
- Audio
- Codec, jumper selectable: Freescale SGTL5000 (I²S)or TI TLV320AIC23B (I²S)
- Connector: 1x 3.5mm jack Stereo Audio in,1x 3.5mm jack Stereo Audio out, 1x 3.5mm jack Microphone, S/PDIF
- Speakers: 2W amplified speaker connectors
- Sensors
- 3-axis movement: ST Microelectronics LIS331DLH
- Light sensor: Intersil ISL29023IROZ-T7
- Compass: Freescale MAG3110FCR1
- Expansion & Connectivity
- Expansion slots: 2x mini-PCIe + SIM cardslot(for 3G communication)
- Ethernet: 1x Gigabit LAN
- USB: 2x USB 3.0 Host, 1x micro-USB 3.0 / 2.0 OTG
- Storage: 1x SATA, 1x micro SD cardslot (SDIO)
- Communication & Control, Header: 2x CAN Bus,1x UART (RS-232), 1x UART (RS-232/422/485),2x SPI (shared with EEPROM), 2x I²C (shared with EEPROM), Local Bus, 8x GPIO (shared with buttons), Reserved / manafacturing pins
- Input power: 12 VDC or smart battery
- 3.5" form factor
- Dimensions: 147 x 102mm
