TA的每日心情 | 衰 2023-3-9 16:16 |
签到天数: 15 天 连续签到: 1 天 [LV.4]偶尔看看III
Embedded Artists的LPC2468开发工具包可以使LPC2468 OEM板快速启动和运行。LPC2468 OEM板为多用途通信应用配备了NXP ARM7TDMI-S基于LPC2468微控制器。基于大板载RAM和闪存,网络和优秀的图形处理能力该套件能高效地运行uClinux操作系统。LPC2468 OEM Board
Processor | NXP's ARM7TDMI LPC2468 microcontroller in BGA package | Program Flash | 128 MB NAND FLASH, 4 MB NOR FLASH + 512 kB internal | Data Memory | 32 MB SDRAM + 96 KB internal16-bit data bus to SDRAM | Ethernet | 100/10M Ethernet interface based on Micrel KSZ8001L Ethernet PHY | Clock Crystals | • 12.000 MHz crystal for CPU• 32.768 kHz crystal for RTC | Dimensions | 66 x 80 mm | Power | • +3.3V powering | Connectors | • Two 100 pos Hirose expansion connector (FX8C-100), 0.6mm pitch | Other | • ISP1301 chip of USB-OTG• 256 Kbit I2C E2PROM for storing non-volatile parameters• Buffered 16-bit databus | OEM Base Board Basic Features
Connectors | • Two 100 pos, 0.6mm pitch Hirose FX8C-100 connectors for OEM Board• Ethernet connector (RJ45)• MMC/SD interface & connector• JTAG connector• Pads for ETM connector | Interfaces | • USB OTG interface & connector• USB device interface & connector• USB host interface & connector• Full modem RS232 on UART #1• CAN interface & connector | Power | • Power supply, either via USB or external 9-15V DC• 0.3F capacitor backup for RTC | Expansion | • Color QVGA LCD expansion connector (serial and parallel interface options) | Other | • 5 push-button keys (4 via I2C)• 5 LEDs (via I2C)• 2 Analog inputs• USB-to-serial bridge on UART #0, and ISP functionality• Reset push-button and LED• Speaker output on v1.5 of OEM Base Board• All OEM Board signals available on expansion connector/pads• 240x150 mm in size |
