查看: 370|回复: 0
LabTool开发板
发表于 2015-4-28 13:20:59 | 显示全部楼层 |阅读模式
LABTOOL是一个其灵活性和强大性仅次于你的实验室工作台!它是一个附加到LPC的板子(基于LPC4370 - 一个具有80兆赫ADC的204兆赫的Cortex-M4和两个额外的Cortex-M0内核)。 LABTOOL利用对LPC4370的所有功能,打造一个强大的开发工具。11 channel logic analyzer (up to 100Msamples per second)2 channel oscilloscope (up to 80 Msamples per second, 6MHz BW)11 channel digital signal generator (up to 80 Msamples per second)2 channel analog signal generator (40kHz BW)        The feature rich Windows software interface supports:One shot and continuous samplingSorting and moving of signalsSPI, I2C, UART signal interpretersProject settings can be saved and restoredCollected data can be exportedFour cursors available to help interpret captured dataPrepared for running under Linux and MACOpen source software
LabTool开发板.pdf
3.07 MB, 下载次数: 0
GMT+8, 2024-11-25 14:24 , Processed in 0.108913 second(s), 16 queries , MemCache On.
