查看: 402|回复: 0
Miniprog3
  • 签到天数: 11 天
    发表于 2014-11-10 10:38:56 | 显示全部楼层 |阅读模式
    The Miniprog3 supports the following protocols:
    • SWD
    • JTAG
    • ISSP
    • USB-I2C
    Included with the kit is a 10-pin ribbon cable for connecting to standard 10-pin JTAG header interfaces utilized for our PSoC 3, PSoC 4 and PSoC 5LP architectures while the device itself supports the 5-pin ISSP programming header for PSoC 1 architectures. The 5-pin connector also supports the USB-I2C Bridging capabilities and is a superset of the CY3240 capabilities. Please note, the CY8CKIT-002 only contains the Miniprog3 and supporting cables.
    GMT+8, 2025-1-15 17:09 , Processed in 0.110175 second(s), 15 queries , MemCache On.
