查看: 487|回复: 0
BCM943341WCD1 Wifi 评估板
发表于 2015-7-22 09:28:37 | 显示全部楼层 |阅读模式
博通BCM943341WCD1EVB评估板打破了BCM943341quad-radio IC的功能。BCM943341WCD1EVB界面带有板载USB接口的用户计算机,可以使用WICED无线网络的SDK进行编程。该BCM943341提供了带有802.11a / b/ g / n的无线网络连接,蓝牙4.0,NFC,以及FM 收音机的2.4/5GHz的双频段解决方案。功率放大器,低噪声放大器,和2.4 /5GHz的WLAN频带的T / R开关也集成到IC上。Features
  • Dual-band 2.4 GHz and 5 GHz IEEE 802.11 a/b/g/n
  • Single-stream IEEE 802.11n support for 20 MHz and 40 MHz channels provides PHY layer rates up to 150 Mbps for typical upper-layer throughput in excess of 90 Mbps
  • Complies with Bluetooth Core Specification Version 4.0 with provisions for supporting future specifications
  • NFC Key Features:
    • Support for the ISO/IEC 18092, ISO/IEC 21481, ISO/IEC 14443 Types A, B and B', Japanese Industrial Standard (JIS) (X) 6319-4, and ISO/IEC 15693 standards
    • No active components required for antenna or field-power conditioning
GMT+8, 2025-1-14 03:19 , Processed in 0.107484 second(s), 15 queries , MemCache On.
