查看: 437|回复: 0
MLX90614 红外温度传感器评估板
发表于 2015-7-24 08:52:26 | 显示全部楼层 |阅读模式
MLX90614的是一个红外温度计的非接触温度测量。IR敏感的热电堆检测器芯片和信号调节的ASIC同时被集成在相同的TO-39CAN。融入了MLX90614是一个低噪声放大器,17位ADC和强大的DSP单元,因此实现高精度和温度计的分辨率。温度计出厂设置为数字的SMBus输出,充分获得了测量的温度在整个温度范围内(S)为0.02°C的分辨率。用户可配置数字输出为PWM。作为标准,在10位PWM被配置成连续地发射所测量的温度在-20至120℃范围内,具有0.14℃的输出分辨率。Features and Benefits
  •  Small size, low cost
  •  Easy to integrate
  •  Factory calibrated in wide temperature range:
    • -40…+125°C for sensor temperature and
    • -70…+380°C for object temperature.
  •  High accuracy of 0.5°C in a wide temperature range (0…+50°C for both Ta and To)
  •  High (medical) accuracy calibration
  •  Measurement resolution of 0.02°C
  •  Single and dual zone versions
  •  SMBus compatible digital interface
  •  Customizable PWM output for continuous reading
  •  Available in 3V and 5V versions
  •  Simple adaptation for 8…16V applications
  •  Sleep mode for reduced power consumption
  •  Different package options for applications and measurements versatility
  •  Automotive grade
Applications Examples
  •  High precision non-contact temperature measurements
  •  Thermal Comfort sensor for Mobile Air Conditioning control system
  •  Temperature sensing element for residential, commercial and industrial building air conditioning
  •  Windshield defogging
  •  Automotive blind angle detection
  •  Industrial temperature control of moving parts
  •  Temperature control in printers and copiers
  •  Home appliances with temperature control
  •  Healthcare
  •  Livestock monitoring
  •  Movement detection
  •  Multiple zone temperature control – up to 127 sensors can be read via common 2 wires
  •  Thermal relay / alert
  •  Body temperature measurement
MLX90614 Datasheet.pdf
2.04 MB, 下载次数: 0
MLX90614 Evalution board USER MANUAL.pdf
1.87 MB, 下载次数: 0
EVB90614_user_manual.pdf
391.39 KB, 下载次数: 0
GMT+8, 2025-1-14 03:25 , Processed in 0.126827 second(s), 16 queries , MemCache On.
